Rum_Pirate
My 22’0” center console Mako is powered by two 85hp Yamaha outboard engines.
There was a termite attack (longish story) and given by the 'nest and debris' the transom core should (definitely long term) probably be ‘repaired/replaced’.
There are a couple of chaps that 'repaired' their soft/watersoaked transom by cutting off the outer fibreglass sheath, removing the timber core, fibreglassing in two layers of plywood and replacing the outer fibreglass sheath.
I have come across Carbonbond CarbonBond Pourable Ceramic Transom Compound which they say is perfect for your next transom repair or new boat manufacture. CarbonBond Transom Compound - Carbon-Core Corporation
The questions that arise initially for me is that they state 'Uses : structural applications where high compressive strength is required'.
Although it does say it has 'high tensile and flexural strength' , it does not say tensile under the 'Uses' section of their site.
Have any of you dealt with a transom repair using this, or similar, product?
Advice, opinions ?
Carbon-Core Corp.formulates its Ceramic Pourable Compound with premium polyester resins and high strength ceramic spheres resulting in high tensile and flexural strength.
Advice, opinions ?
