Searush
OK so it's only a dinghy, but my 1958 GP14 had a loose lower rudder pintle & removing it revealed some water penetration around the bolt holes. The previous owner had filled the damage with silicone bathroom sealant & thro bolted the fitting with mere steel bolts & washers. I am considering drilling out the bad wood & aralditing in a bit of dowel (1/2" will do it) before drilling new clean & close fitting (4mm) holes. I have limited woodworking tools or skills & this seems an easy & satisfactory solution.
I have bought s/s countersunk set screws with penny washers that will overlap the dowel on the inside & the pintle fitting will cover most of the dowel on the outside, so in effect the dowel will just be a hidden spacer. Clearly I will use a decent marine sealant on the bolts, washers & pintle. If I could find my Aldi hole cutter set I would have cut some plugs out of marine ply to fill the holes in a more professional manner, but it is stored somewhere "safe" & I know not where. :nonchalance:
Any comments about my plan? I'm sure most of you could make a completely watertight & invisible repair, all I need is strong & waterproof - oh & suitable for an incompetent to achieve easily. :encouragement:
