transducer
reginaldon
20 Feb 2004
kent
Another new owner having difficulty in differenciating between a and e . I need to fit an e. s transducer to a grp caprice (B/K). any advice please on fitting and best location. Thanks in anticipation!
reginaldon
20 Feb 2004
kent
'a... and elbow' johnnygil, yes echo sounder transducer to a 18' Caprice (B/K) = sorry to be obscure
oldsaltoz
4 Jul 2001
Australia, East coast.
G'day Reg,
Drop the transducer into a plastic bag and splash a little water under it to make sure there is no air trapped under it, move it around to find a location that has good readings and good access, do this when underway in case turbulence is a problem.
To secure it, an off cut of PVC pipe held down with some blue tack will hold the slow set resin, mix and pour, then wait for any bubbles to surface, pop in the transducer at an angle to start with, this should help prevent air being trapped under it, rotate it a couple of times to remove any remaining air and hang it by it's wire till the resin sets.
If the tube is likely to get stepped on when the floors are lifted, you could glass the PVC pipe to hull, note, if you plan to do this, run a very hot heat gun or flame over the PVC prior to starting the job, the burning will ensure the resin and glass will stick to the PVC.
By the way, welcome to the forums and your third post, good to see some new blood; no doubt you will get more advice from other helpful forumites.
Good luck with the project and Avagoodweekend.....
<hr width=100% size=1> Old Salt Oz /forums/images/icons/cool.gif Growing old is unavoidable. However, growing up is still optional.
reginaldon
20 Feb 2004
kent
Hi Oldsaltoz - thanks for help and kind welcome. Sorry to be obtuse but are you refering to glassing the t. inside the hull or through the hull - I thought it had to be drilled thro' and secured - I said I didn't know my a from my e!
oldsaltoz
4 Jul 2001
G'day Reg,
After drilling the hole/s you must coat the raw glass to prevent moisture entering the hull; this best done by drilling oversize, sealing with an epoxy resin and, resize after the resin has cured.
Hope this helps.
