Transducer oil
darrellbate
23 Sep 2022
Hi
I have a Nasa Clipper depth transducer and need to top up the oil in the hull mounting. does this need to be special il or can anything do?
Poignard
23 Jul 2005
South London
Educate me
Depth transducers need an oil top up?
My Raymarine setup either doesn’t need it or I’ve neglected it for the last 20 years :unsure:
I installed my NASA Clipper echo sounder transducer in 1998, filled its mounting tube with the oil supplied, and have never disturbed it since. No oil has leaked out and the instrument works perfectly, so I can't see any point in meddling with it.
ChromeDome
25 Sep 2020
When fitted inside the hull there must be no air between the transducer and the hull. Hence fill the kit with something harmless that will not freeze - aka coolant.
Jon4468
11 Jan 2021
Thank you for the reply and pics
Live and learn
I’ve used various liquids, neat anti freeze, olive oil etc but I’ve found fairy liquid ( other brands are available) works best and there’s no worries about spilling it. This is in my airmar 72? In hull transducer.
jrudge
4 Dec 2005
Live London, boat Mallorca
Only if they leak which sometimes they do at the seal. I have one in my willaims rib that has leaked from nee. I have now disconnected it
