m1nder
Active Member
The old trailer belonging to my N17 has a central steel beam, 100mm wide by 50mm high, hollow. I need to fit new keel roller brackets but cannot source bracket/u-bolt combinations any wider than 80mm (bolt hole fitting)
I could drill through the beam top and bottom and run individual bolts to hold a keel roller bracket but then I loose the ability to move and adjust it along the beam to suit the keel curve.
Can anyone help me with suggestions as to what I can do here?
I have searched the web black and blue.
