superheat6k
I have a small but persistent leak which appears in the aft corner of the port berth in the fwd cabin. The bulkhead separates from a large locker running right across the boat, this locker stays dry. I can't see where this water tracks along from. Over the Winter ~2 pints of water have collected in the locker below the berth, and this had previously saturated the mattress and rotted the cover, so I now leave the mattress propped up off the berth.
There is nowhere obvious as to the leak's source. I have thought about sealing the cabin and partially pressurising it with a bouncy castle fan, then soaking the deck area above with soapy water, the idea being that bubbles would form at the water entry point, but could I cause damage using fan pressure.
Any other ideas ?
Any other ideas ?
