jon_bailey
Last time I was out with my boat suddenly developed a vibration whilst cruising. Problem was traced to a 'flywheel' that had come loose from just behind the pulley on the crankshaft. Also lying in the bilge was a rubber gasket approx. 25mm x 3 mm.
Looking through my Clymer manual for a Mercruiser 4.3LX, this flywheel is apparently associated with the torsion damper and I assume that the gasket is also. So I have the following questions:
1) What is the torsion damper and how does it work?
2) Where does the rubber gasket go?
3) How is the 'flywheel' attached to the crankshaft or is it just a friction fit with the the rubber gasket?
None of this is clear from the manual.
BTW managed to get back into Lymington safely after knocking flywheel back onto crank.
All advice gratefully received.
