collinsp
Active Member
Hi guys,
I have to patch/fill a few areas on the coach roof, cockpit and scoop stern and wondering if it is better to use Gel coat or Top coat ?
I recently used Gel coat on the underside of the cockpit locker seats as they were almost yellow
but found the gelcoat was setting way to quick, even using only 1% catalyst. Also did use the remainder of the pot to touch up a few tiny areas without catalyst and that has taken nearly 4 days to set :-( so won't be doing that again . . .
Any examples/experience you guys could share on the Gel Coat/Top coat would be much appreciated.
Thanks . . . .
Thanks . . . .
