Tool for rudder "nut"?
25 Feb 2010
I don't know but the tool for removing disks on angle grinders may fit.
If not then it may well be quicker to make your own tool rather than chasing around trying to locate one.
Edit;
PS OK, it's a peg spanner!!! You learn something new on this forum every day.
Playtime
29 Jan 2007
Chichester
If you can take the weight off the thrust bearing (by lifting/jacking gently the rudder from underneath) you can probably remove the nut/bearing by hand. :)
nortonmotors
13 Feb 2006
me: Lincolnshire / boat: Maldon
Is there a slot in the side of the nut, and does that screw tighten to close the slot, thus making a locking nut out of it?
Might be worth checking before you spend time on a strong peg spanner.
savageseadog
19 Jun 2005
Or pin wrench
I've made my own, it's possible to use screws as pins, preferably turned down but not essential
