gandy
Hi,
This wasn't one of the jobs I was expecting problems with, but I am totally failing to fit the new "Leesan" hose onto the Blakes seacock.
The hose (marked 38mm) has a static internal diameter of just over 36mm. The hose fitting on the seacock has an outer diameter of 41mm. After a number of fruitless sessions trying to get it to fit I have to face up to the fact that the hose is simply too small. By heating it right up I can just about stretch it to that size, but its then too floppy to be forced down the fitting. The best I managed was to get the hose on for about 1/4in, but at that stage it developed a split.
First question. Does the panel think that the hose should be able to stretch that far? If so I could do with some suggestions, I've tried hot water, fan heater, conical wooden bung,
Second question. Does anyone know where I can get hose with a larger ID? All the suppliers I've checked have the same size, nominal 38mm ID. The connector at the SL400 toilet is 40mm diameter, so the same size hose should fit at both ends.
Thanks in advance,
Does anyone know
Thanks in advance,
Does anyone know
