Greenheart
This is an idle enquiry about a general point, not specific to my own boat or purposes.
Tohatsu outboards seem to be available with different sizes of propeller, to suit a range of applications.
The 20hp can turn a maximum 10" prop...while the slightly more powerful, 25hp 3-cyl is available with a big 14" prop.
The latter sounds big enough to drive a substantial displacement hull...
...but you will probably have noticed in all photos of outboards, that the propeller blades' outermost 'turning circle' passes extremely close to the horizontal 'fin' protruding from the shaft just above the prop...
...so, assuming the photograph is not of the very largest propeller, what modification of the shaft must be undertaken, to make room for an extra two or three-inch radius of prop? (I'm not asking about adjustments to internal gearing, which the manufacturers must recommend for non-standard prop sizes.)
I don't know what the little fin or tab is called - nor how critical it is to the engine's performance. Any comments? Thanks.
Here's the page where I found the data: http://www.tohatsu.com/outboards/25_4st_spec.html
