CorrosionNut
New Member
Just a word of warning if you own or are buying a new Tohatsu, Mercury or Mariner 25 or 30 two stroke which are all in fact Tohatsu only the label is changed.
In my opinion they have a design defect that makes them prone to corrosion if you are using them in salt water. I have raised this issue with Tohatsu Japan and they disagree, so you can be the judge of the situation.
These engines all have a large aperture about the size of your fist under the carburettor in the bottom of the engine shell. This aperture is not at all obvious. This will allow salt spray and water to enter the engine bay. To make things worse the engine cover is also vented at the top so the spray can blow straight through around the engine. This may mean your engine gets coated with salt over the summer season and may sit corroding over the winter months unless you have a serious desalting routine as part of your corrosion prevention.
In Australia, New Zealand, and the Pacific Islands these engines are sold with no mention of this serious short coming to unsuspecting purchasers like myself. I don’t know if this is the same elsewhere but I suspect so.
This problem has been recognised by Tohatsu Japan since 1985. I have their dealer maintenance bulletin (sent to me this month) of that year that states this. The bulletin shows that the engine cover was redesigned to incorporate a baffled air intake for the carburettor in the tilt hand grip at the top rear of the engine. A new grommet was designed and is available as an option ????? to close of the air intake under the carburettor and it notes that this helps stop corrosion.
The part number is Grommet D, Lower Cowl Part # 346-76161-0
In my opinion for salt water operation
1. All new Tohatsu/Mercury/Mariner 30 and 25 two stroke engines need to be fitted with the Grommet D, Lower Cowl Part # 346-76161-0 before they are sold in the Australia, New Zealand and the Pacific or anywhere else.
2. All such motors already sold need to be fitted free of charge with Grommet D, Lower Cowl Part # 346-76161-0 at their next service. All customers need to be sent a letter to inform them of this.
