Tohatsu 3.5b2 fuel cap breather seal
ctb
Active Member
22 Apr 2010
Glasgow
It seems that its not possible to buy the fuel cap breather seal (black rubber seal between the white "screw" and the black fuel cap) from Tohatsu. Mine has a small tear in it probably due to overtightening. Does anyone know of a source for one of these. A new fuel cap is around £20, I've tried using a piece of bicycle inner tubing to fashion a replacement but it leaked. Also tried a piece of rubber door-mat; same result.
Thanks.
Geoff
I have replaced several washers on pressure lamps with ones cut from offcuts of Treadmaster. Basically a cork and rubber matrix. Put cork gasket into ebay you can buy a sheet that will last you a lifetime for minimum pounds.
I had the same problem and stupidly used a tap washer which disintegrated with the fuel and blocked the small breather hole !
Second attempt has proved very good made with a thickish piece of leather.
Go to a builder's merchants. They usually have a range of plumbing seals and the outlet seal from a cistern would probably cut down well to suit your requirement.
Its only the small washer on the vent screw .. at least I think that what he means.
Test any bits of plumbers stuff in some gasoline for a few days to be sure it's suitable.
A fibre washer might do the trick or it might be too hard
Yes, that is what I meant.
