Toerail fairlead
PabloPicasso
12 Feb 2010
Anyone know wherw I could get a toerail mounted fairlead. See pic. Its aluminium and 6"inches long.
Most fairlead have vertical bolt holes for deck fitting. I need horizontal bolt through.
Thanks all
superboots
26 Feb 2002
I have a pair designed to fit the same toerail but closed with side rollers I was going to fit to my Moody which has long since been sold. You can buy new but are very expensive. If you don't find any others you can pm me but I am away for some time
rogerthebodger
3 Nov 2001
MIDDLE FAIRLEAD FOR TOE RAIL 823 - International Boat Spares
Iliade
27 Apr 2005
Shoreham - up the river without a paddle.
www.airworks.co.uk
Mine are closed loops and don't like being loaded by rope from above. Hence I got a local stainless steel smith to fabricate one in s/s for me. He sand blasted it and it was a perfectly adequate visual match for the original and a lot stronger.
Ones like yours would be pretty easy to cut from a solid block of aluminium. Woodworking tools generally suffice.
Worst case, it is not rocket science to cast and anodise your own...
Refueler
13 Sep 2008
Far away from hooray henrys
Not the same but a few here.:-
toe rail fairlead - Google Suche
I like the Osculati roller versions .....
I have plain fairleads in my fwd toerails and I have already had a chafed line through port side ......
I had 'hose-pipe' protectors but they wouldn't stay in place ...
I'm thinking about fitting folding cleats to outer side of toerails ...
Daydream believer
6 Oct 2012
Southminster, essex
Fairleads can be more trouble than they are worth. I tend to lead any ropes straight over the side from the cleats. There is less chance of chafe & less squeeking when moored in a rolly pontoon berth. Of course, if the rail is timber, then wear on the timber can look unsightly, so best avoided
ricardio
27 Dec 2010
Refueler
"I had 'hose-pipe' protectors but they wouldn't stay in place ..."
Three hefty cable ties on the line at 120 degree spacing just below the hose pipe will keep it in place. Particularly good for lines left permanently on the pontoon at your home berth.
Refueler
13 Sep 2008
Refueler
The pipes were quickly added when I first brought the boat over ... then we had a storm go through and line parted ..
As to what we do as a more standard measure - is still being worked out as I may not use that berth again .. I may choose the Baltic Moor section of the 'Marina' ....
The cleat / fairlead / toerail design of the boat is not the best ... if you look back at the picture posted ...
Martin_J
19 Apr 2006
Portsmouth, UK
Those IBS ones and all of the other photos above seem to show fairleads that need the horizontal deck part of the toerail removing as well (since they form the deck part as well as the upright.
In the original post, I see that the cutout is only needed on the vertical part of the toerail...
Martin_J
19 Apr 2006
Portsmouth, UK
The Moody Owners forum seems to suggest they were made by SL Yachting, based near Chichester. Their website doesn't really work but others have had luck contacting them via Facebook..
