Is it Teak or just venire? If the later you need to be careful not to sand through. You can put new venire on but it is not cheap. Sand and varnish is my preference. I use epifanes gloss varnish which works well but you need to put a good few layers on
It looks like solid wood from the photo but a high chance it could be veneer. If solid it wants a dam good seeing to with some 180 grit sand paper and upwards followed by as already mentioned epifanes high gloss. Lovely stuff
If the oil is through then you’ll either have to live with it or throw it away as I’d guess it has soaked in quite a way?
Almost certainly very neglected teak veneer over ply. The capping round the edge is solid teak used to cover the end grain of the ply. As said the veneer may be very thin so will not stand much sanding so you will be lucky to get it back to good condition as the water staining will likely be deep. Suggest you use one of the proprietary teak cleaners and then see what it is like hen all the surface muck is removed. You may be able to shift the stains with oxalid acid and a light sanding. Once you get it to a respectable finish suggest you use International Woodskin to coat it. This has a light stain which will help get the colour more even, but most importantly it is breathable so will not crack or flake. Very important if you want to leave it outside. If it is solid teak then you can be a bit more severe with sanding, but otherwise the treatment is the same.
Best thing you can do to extend its life once you have renovated it is to cover it up when not in use.
