SvenglishTommy
I have a dilemma regarding the protection of my electrical system. I recently completely re-wired my boat and changed the layout a little. The main problem is that the batteries are located at the front under the v-berth and there is a long run back to the starter and everything else.
To make things easier I have tried to bring the battery terminals aft by using oversized wire to heavy duty connection blocks that are much to closer where I would ideally like the batteries to be. I then base all my voltage drop calculations from this position as the drop over the 10M (there and back) run is negligibale to anything but the starter motor.
My concern is the length of unprotected wire that this leaves. I have two 100A circuit breakers that I was thinking of installing close to the batteries as a protective measure, but I'm not sure if this is a good idea as they would then be part of the starting/charging circuits. Sorry if this doen't make much sense, maybe I should post a diagram, but any advice would be much appreciated.
