prv
Kindred Spirit lives in a marina berth that dries for a short while on springs. The engine intake seacock is not the most accessible - reasonable in an emergency, but once I rebuild the bunk it's under, a bit of a faff for routine use. I'd like to leave it open all the time, but there are two possible reasons not to:
1. All the water could fall out of the hose, and not go in again when the tide comes back, resulting in running the engine dry. The highest point in the system is the strainer, which is a couple of inches above the waterline. If you open it while afloat, the water stays in the strainer body. My dad (with whom I share the boat) is very keen on there never ever under any circumstances being any air in the intake hose, and closing the seacock before drying out is therefore mandatory. I'm of the opinion that the pump will be able to pull through a brief bubble in the supply without any trouble; it starts off wet as the hose from strainer down to pump never empties. The pump is new after an engine overhaul.
2. The hose could detach itself from the seacock and flood the boat. Strangely, my dad is terrified of this happening with the engine seacock, but is apparently unconcerned by either of the toilet seacocks, the cockpit drains, or the galley sink, all of which are left open. I can't really envisage this happening, since the hose was an incredibly tight fit on the nipple (would need to be cut to be removed; it's probably a size too small really) and is then secured with two good jubilee clips. The pressure differential in the joint is as near zero as makes no difference (the intake is inches below the surface) and the seacock is in its own partitioned-off space with no stowed gear to molest it. It's hard to think of anything which might cause the hose to separate.
Thoughts?
Thoughts?
