Spyro
Old set up on the boat was the Battery Negative was connected to the engine block and so to the gearbox, coupling and propshaft. Thus earthing the whole dc negative side (when in the water)
I have fitted an R&D flexi coupling and have bridged the coupling electrically thus to keep the DC -ve earthed through the shaft.
What difference would it make if I had isolated the shaft and prop from the negative side. I know all my electrics would still operate ok because they do when the boat is on the hard but does it make a differnce to a shaft anode etc or corrosion on the prop. Would my shaft anode or engine anodes last longer if it was isolated?
