VictorII
I have a TMP 2-pinion gearbox (mk II) but it has developed a hole next to the water output. This seems a problem that occurs often as some marinisers used to employ copper based pipework.
I would like to fix this but I am on the European mainland and have no knowledgeable (about TMP) mechanics around here. So I set out to do it myself - apart from the fixing of the hole.
Has anyone taken the TMP apart? I would like to do it with the engine in place by only removing the reduction box. Is this possible? I have the manual but it isn't clear on the topic. From the drawings I can't tell if there are any internal bolts which require the entire gearbox to be taken off (55 kgs!). If I should have to go this way, I'll have to reopen the engine room top and I've only just refurbished it last year, so would only reluctantly go this way.
In the manual is stated that when the bolts are undone, tapping with a felt tipped hammer should take the gearbox and reduction box apart. I have got the bolts off, but there is no movement in the box. How hard should I tap? Does heat help and where should I apply it?
Any advice is much appreciated!!
