dylanwinter
I think that I have got my head around the maths of getting the lip of the so far theoretical outboard well at the right height
with a standard long shaft the clamps will,I think, be 100 mm above the level of the cockpit floor
200mm above the waterline
is that enough? I would guess that is about the same as Katie L and this well is closer to the centre of the boat than Katie Ls
The well should accommodate a long shaft 9.8 and a long shaft 15 hp (not at the same time obviously)
the ultra long shaft will go much deeper
I will not know for sure until I get to a boat and have a good look around
all the details of the engine dimensions are here
http://www.keepturningleft.co.uk/scuttlebutt/designing-a-well/
the ultra long shaft outboard will be running pretty deep
does that matter?
will there be excessive back pressure on the exuast
all that aside
I was wondering if anyone had any tips on removing an inboard
can I remove bits to make it easier to shift
head off, fly wheel off?
then once it is free I assume I can slide it back wards into the cabin
then what?
Can four strong blokes lift it out?
can I use the boom as a lift?
will I need to make a frame?
once it is in the air - then what?
has anyone removed a Centaur fuel tank?
does anyone know of any urls of images of the job
Dylan
does that matter?
all that aside
then what?
Dylan
