Tips for freeing sized boathook
Could possibly try applying a bit of gentle heat with a hair dryer/heat gun on the twisty bit followed by a few gentle taps with a hammer. Certainly worked on a seized extending pole that I have.
If its the same type as mine, I freed it by taking the rubber handle off and pouring boiling water into the handle end.
This enabled me to push the locking mechanism out of the handle end to be cleaned and lubricated.
Plank
Mine has also become stiff. The only way I can extend it is by jamming the hook end between my boots which gives me two hands to pull it up. I've eased it before using hot water but it's due for another treatment. It's the salt that does it. Some silicone grease might help.
Gentle taps, twisting to and fro, pulling.
For prevention I drilled a 6mm hole in the end of the rubber handle and a lot of white dust fell out. The hole now serves as a drain for any water that gets trapped inside. Pumping the two parts up and down before putting the boathook away blows droplets of water out of the hole in the handle (if this is held at the bottom). So far, this has been a successful solution.
i was given one like that
i've been leaving it in the rain/dunking it in salt water as i want it to lock extended - i use the boat hook to push off from pontoon etc/fend off dinghy etc
can we swap?? :-)
:) x2
:) x3
:) x4
:) x5
:) x6
:) x7
:) x8
Sorry...
I think that my telescopic pole was bought at the same time as the boat, in 2000, and it's still going strong. We also have a proper one stowed on the coachroof. It is handy to have a spare at the helm when going into a lock, though I seldom have to use it. I think the innards are nylon or summat, so washing out should be sufficient, but I might try some PTFE if mine got sticky.
I had a telescopic boathook that failed the other way, i.e. it came apart, I think because the adjusting gubbins was held in place by a plastic external sleeve which came unglued from the alloy tube. I reassembled it as best I could but one tube would no longer grab the other, so I ended up fully extending it and putting a couple of blind rivets in. I now have a fixed-length boathook, distinguished from its still-telescoping twin by a band of red tape (so I don't try telescoping it by mistake).
