Tinned copper wiring
missed ones
  • advanced power boat
    Votes: 0 0.0%
  • ocean YM
    Votes: 0 0.0%
  • Total voters
    0
Did the "Yes" bit, but in fact DC is mostly tinned (but not the patch pieces between the termination strips on the DC board, and also the large high current cables eg ex battery to DC board, alternators and inverter) and AC is not tinned.
As generally found all supplied cables with radios, pumps, etc is not tinned and is same on our boat. Personally don't think the tinning is a big deal unless one is into wet old boats with manky wiring.
Boat is a professionally built custom sailboat built for us, 9 years old. Builder was of very high reputation.
John
Boat is Macwester 30 (yacht) built 1971. I rewired once in automotive quality wire 5 years ago and have since replaced all the cables which go outside the boat, mainly to lights, as the other wire turned black due to the salty environment.
FWIW its a Windy 8800 - 1986. There are some wires that were put in by a previous owner and they were steel. Guess how long they lasted. I stripped them all out as they had turned to dust inside.
Personally, I think they should be all SS and should all applicable metal components on a boat. (SS wire is available)
Mine are tinned, the terminal ends last much longer, without corrosion. It is the right way to do it.
One of wooden build. (boat type)
Ah, for a perfect world.
Sadly, SS is ten times or more resistive than copper - so to get a length of cable with the same current carrying characterics you would need to increase the CSA dramatically.
The only common ductile metal with better conductivity than copper is silver ..... now fancy that - a boat with silver wiring! (mind you, the corrosion would be something of a problem)
It makes little general differance. If based on panels we have had back for refirb, they were built with untinned tri-rated cable, over an age range of 10 -20 years.
We have some with bright copper cable after 20 years, and others with black cable after ten, we have them with some bright and some black, but non were it's required cable replacement. It would appear that the black cables are the ones that are on all the time, the one that are used intermitently are usually bright copper. Sea water running on panels will give rapid corrosion, and tinning does seem to have little effect.
What I have noted is that after 15 / 20 years female spade connectors are getting very brittle, and the tang that raps round the blade is breaking off. Were we have soldered cables to switches and PCB's, we have had no problem.
The above is based on a sample of around 200 switch panels out of around 7,000, covering 20 foot - 50 foot boats, so is a random snap shot.
Me? I always us tinned copper for signal cables, and a good qaulity tri-rated cable for power us, though if find a tinned option I would use it, as you will not be any worse off, and it looks good for the customer.
Brian
