Tightening Volvo Ignition Keyswitch?
Vulcan
22 May 2004
France
Is there a special tool to tighten the Volvo Penta 859573 Ignition Keyswitch? The plastic bezel at the front just screws onto the plastic body of the switch which projects through the panel. There is not much to get a grip on at the front to adequately tighten it. I don't want the switch to rotate which will just strain the wiring at the back. Any thoughts?
nickfabbri
1 Sep 2006
did mine yesterday. take the entire panel off ( there should be 4 screws holding it in ). if you look at the reverse of the switch there is a metal nut which you can tighten from the other side. that should fix it.
