Iain C
My MOB kit consists of the following:
-Ocean Safety inshore danbouy. Bottom stowed in a piece of drain pipe lashed to the pushpit, flag flaked into a piece of tube dangling from he backstay (carbon fibre I'll have you know!) And with about 2 metres of floating line it's tied to...
-Horseshoe lifering. Stowed on a small ally bracket on the outside of the pushpit. Held on by a piece of bungee which keeps the floating line to the danbouy neat. In turn it's tied to...
-A drogue, attached to the lifebouy grab lines. The drogue is stored in a small plastic pouch cable tied to the pulpit.
-And a floating light, stored upside down in a plastic clip on the ally lifering bracket.
Should all this lot be tied together? My concern is that if I needed to launch it, I need to undo the bungee, drop the lifering over the side, make sure that the light unclips, make sure the drogue comes out its pouch, lift the bottom of the danbouy out, and make sure the top clears the flag storage tube. If any of this goes wrong, I could end up towing it about uselessly.
However, I do see that if everything goes over together, it's all in one place, hopefully near the casualty. However there's also a chance of fouling the prop on the floating line on recovery. I also see the benefit of having the danbouy loose...in many ways my primary aim is to mark the position...hopefully if it's remotely fruity, or dark, the MOB will have a lifejacket with light on so the ring is of secondary importance.
So what is the best plan? Danbouy loose, or with the ring and light? What about drogues? One on each?
(And yes I do have a throwline too)
