davethedog
Hello all,
Oner of the projects I am looking to do in the next few weeks is to tidy up the Nav station wiring (that is hidden from view) as it is a bit like the proverbial "snakes wedding" behind the panel. It all works well and no where near as bad as some I have seen but it could be better.
So the questions I have are:
- can I run all the negatives from a single negative bus bar?
- Same for the positives that are on the same circuit, eg the AIS transponder and VHF radio are both connected to the same breaker at the switch panel.
- Best way to lengthen the wiring, as some of it is a little bit tight with not much room to move the panel.
- I am planning to use a lot of cable ties to really tidy it all up, good practice?
Anyway, await the responses and hoping this does not cause any "heated discussions"!
DTD
DTD
