essexboy
Might seem a silly question, but when is it officially high tide ? Is it when the water first peaks, or half way through the high period ?
In some places (Poole for example) the water does not rise equally so there are two "high" points each cycle, so you have to refer to the tidal curves to determine when it is at its highest.
...and Reeds have pretty much given up on the whole concept, and refer to tide times in Poole by low water instead
Leaving aside the double high tides in the Solent, the question is actually based on a false premise. There is no high water "period", because high tide exists only for one instant in time. The water level is lower than the peak (a mm or so) a minute before and a minute after high tide, and is at its peak only for an instant, midway between those two times.Might seem a silly question, but when is it officially high tide ? Is it when the water first peaks, or half way through the high period ?
So is Southampton! It is because of the double high that low water is shown as the base. In fact the whole of the Solent's tidal curves are based on low water apart from Portsmouth.
Sorry, yes. I was thinking of the fact that they don't even print high water times in the Poole table. They have a height, but the times are blank.
They do in Easytide and our local printed tide tables which are from the UK Hydrographic Office. Some tables just use the times, other print out the tidal curves. Both have their uses. You can download Easytide tables and curves all in the same document.
It's easy, high tide in Poole is when you don't need to get in/out of Parkstone Bay Marina and low tide is always at the point when you need to get back, but can't because there's no water.
