Tide time differences....
l'escargot
Isle of Wight / Jersey
They are only predictions. Different models come up with slightly differing results. Reality will often differ from all the predictions too. There is no totally accurate way of getting a tide time.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
and as the curve is more an inverted U than a V you would need a lot of sample points or calculus to find the max, and it depends on how many harmonics are used, and it depends on the weather that day.
Oh hell, it's just a best guess, but a bit better than a weege board or consulting an astrologer!
Kerenza
19 Sep 2011
Newport
www.24bit.ltd.uk
Just working out some tide times.
Leaving Cardiff for Bristol on evening of 4th July.
Harbour Authority gives 1740 3.5m
Local marina LW 1754 2.9m
Neptune planner 1810 3m
Navionics 1815 3.07
Lock times outbound on the hour and half hour.
35mins and 0.6metres difference.
2.5m draft plus 2m siltation. total clearance needed 4.5m
1830 Ok by harbour authority
2000 OK by Navionics
1830 will hit my window for river entrance, 17.5Nm distance - (if I can believe that tide prediction)
2000 I'll be late!
Think I'll call the astrologer!
Giblets
5 Mar 2006
Surrey
Navionics 1815 3.07
2000 I'll be late!
Probably best to go by car then! :cool:
bitbaltic
21 Nov 2011
Boat in Milford Haven
sailingkarisma.wordpress.com
Navionics 1815 3.07
2000 I'll be late!
We sail from Cardiff. Notice you don't mention reeds in your list of tide sources.
We always use reeds and always do the secondary port calculation. Results generally very accurate when we check height of tide with barrage control. Your sources are all local data where the secondary port calculation has been done by the source in ways unknown to you. Doing it yourself removes an obvious potential source of error and variation (that tide predictions are approximations notwithstanding.)
Main problem is the embarrassing degree of silting always in the approach channel regardless of design specs or recent dredging. Barrage usually very reluctant to be honest about it either, suggest calling them for a lock out at low water with your draft to get real numbers from them. However 2m (1m sill and 1m silt) sounds about right at the moment.
Cheers
Kerenza
19 Sep 2011
Newport
www.24bit.ltd.uk
They could all be correct! Remember U not V
It just depends where the software takes the sample points.
Point (sic) taken, but even a U must have an origin?
Bitbaltic
Reeds uses UKHO, accessible as easytide. Usually similar to Navionics, by manual calc or from Internet site. Neptune also uses UKHO !
HA use Proudman which should be the most accurate prediction. It's what the barrage uses.
No cil to worry about- 2m silt, due to be dredged next month.
Ploughed all the way in last Friday evening, we got clear over the entrance, then stuck alongside. Flows scour the middle of the lock. Back to a u shape!
Mark-1
22 Sep 2008
Seems most likely explanation. In terms of time the low/high points must all agree exactly on average otherwise they'd drift apart by an increasing amount.
