Tidal Rates Chart - Falmouth
Tim Good
26 Feb 2010
Bristol
I just got the Channel Almanac and although they include the tidal curves shouldn't there be a computation of tidal rates graph also for Dover in order to calculate precise rates based on tidal diamonds on the charts?
Might be loosing the plot here but any advice appreciated.
Cheers
Tim
If the chart is not there, PM me and I can email one. Remember that greater precision in rates does not necessarily result in greater accuracy.....
Keith
Brest is best
Not sure I understand exactly what you are after, but for tides around Falmouth, where I sail mostly, this is what I do:
1. To determine the rates on an hourly basis I use the channel stream atlas but use time of HW Falmouth offset by 6 hrs from that of Dover (eg Dover +3 = Falmouth -3).
2. To determine the peak rate I use Brest coefficients. These have the advantage of being printed in the almanack. Brest is also rather closer to Falmouth than is Dover, not that that necessarily means much.
I've not found that the tidal diamonds give any superior precision to the stream atlas since they are far apart and thus ususally fail to show any eddies or counter currents. For instance the tides between the Lizard and Black head can be upto 1 1/2 hours adrift from what you'd expect; close in to the east side of the Lizard the tide turns SSW while the main current off the Lizard is still running E. This can be useful if going W early on the tide, but if running east in a westerly blow can build up big seas just at the point you would expect to come into smoother water having some shelter from the Lizard.
The best inshore Tidal Stream info is in a small booklet by Mike Fennessy 'Tidal Stream Atlas of the South Cornwall Coast'. This covers Penzance to Plymouth and shows back eddies etc.
The UKHO also produce one, NP254 Falmouth to Teignmouth, which although much better than the almanac is not as detailed as the Fennessy.
Mike Fennessy also produced a South Devon TSA but this is currently out of print.
For an explanation of how to use Tidal Stream Atlases and Tidal Diamonds have a look at www.cockpitcards.co.uk
south cornwall tidal straem atlas
Does anyone know where to get a copy of this, they seem to be rare as hens teeth
No!
Tidal rates are taken from tidal diamonds on the charts w.r.t the Standard Port High / Low Water for the area.
AFAIK that info has never been in an Almanac, the nearest you get is as per the attached thumbnail.
Yes :D
