Oaks81
Is the propeller supposed to be able to move back and forth on the shaft? Mine had over 1 cm of slack and someone in the dock pointed out that it is not supposed to.
The propeller got slightly damaged last summer and my mechanic sent it for repair. I received it now from the workshop and I tried to install it by myself for the first time.
The thrust washer was still in place and it was bit difficult to remove due to oxidation. I greased the parts and put them back in the same order as they used to be. At this point, I noticed the slack.
If I turn the thrust washer around, there is almost no slack. I will attach a picture of how the washer was.
