sam_uk
When in a chandlers somewhere I spotted a clever device. There were two plates one that fitted either side of the floor of a dinghy. The two plates screwed together.
Both the plates have a hole in the centre and when attached together there is a hole in the middle with a thread around the hole.
You cut a circular hole in the floor of the dinghy, then attached the plates both sides and screwed on the plastic cap.
When you want to securely chain up the dinghy you unscrew the cap, and pass the chain through the hole. Then to steal the dinghy you then have to cut the tube rather that just cut off the flimsy shackle.
Does anyone know what these hole things are called, or where I can get one?
Sam
Sam
