raquet
Having just fitted a new mast with new electrics (lights & VHF) I now have long coils of cable at the foot of the mast to connect appropriately. Do I:
1) Cut the wires above deck and fit deck sockets – this will probably mean renewing the wiring below decks as there is insufficient to run to meet the sockets.
2) Feed cables through waterproof deck glands then cut and join to existing wiring below deck.
3) Feed cables through waterproof deck glands and run same cable through to source.
The last option only makes sense for the VHF as it leaves no joins – however I’d need to cut it if (when) taking the mast down. The second option has no joins on deck but makes removing the mast slightly more difficult – depending on the type of below deck join used. The first seems to me to have most risk of ingress of water into the connection.
