Summer breeze
New Member
Having read through hundred of posts on this and other sites i need to post a fresh thread as i am having real trouble locating a problem
I am running a 60hp mercury outboard from 1991/2
starts and runs fine, regularly serviced and it keeps coming back from the garage with "there is nothing wrong we can find"
problem is, on opening throttle, as you push forward past 3\4 on th way to WOT the engine bogs down. it is like the engine is starved of fuel. the revs drop off and the boat falls almost of the plane. now that is similar to may issues i have read on here.
the issue is that if i keep pushing the trottle the engine comes back to life and will run at max\optimum revs and sits comfortably on th plane at full speed.
any ideas what this "trough" in the throttle curve may be and how i might rectify it.
thanks in advance
glenn
thanks in advance
glenn
