Throttle/Gear lever position in storage question.
ThreeSummers
12 Jul 2006
Walker Bay, South Africa.
My outboard control lever stands quite high above the coaming of the boat, which gets in the way of the boat cover - my last cover started tearing in this spot as a result.
Would it cause any problems if I leave the lever in gear in full-forward position when storing the boat to keep it from getting in the way of my new cover?
Regards,
Tim.
For sure moving it to " just in gear" is fine. Moving it fully opens the throttle butterfly if that's mechanical. Not if its controlled by a stepper motor but I don't think yours is. This, being pedantic, leaves an airway open and damp/moisture can get in but IMHO that is verging on anally retentive and I wouldn't worry about it. Your engine is Efi afaik so you don't need to worry about a squirt/puddle of petrol in the intake from an old school mechanical throttle pump
