dunedin
Having had no problems with this previously, having a range of fun and games with the throttle controls these past few weeks
The cable failed in August - and was replaced by the yard engineer at Crinan. Cable was very slightly longer than the one removed (5.5m vs 5.25m) but otherwise seemed to be working fine.
However having been little used in the following weeks, am now having problems with the engine revs not dropping back when the throttle is moved back to neutral - stays 1,500+ revs unless manually pulled back at the engine end.
Stripped morse lever and no visible problems. Ditto at the engine end. Cable clearly new.
Jury rigged a bungy cord to pull throttle back to get into berth - which works to reduce revs as a temporary measure, but this doesn't allow use above 1/2 throttle and a bit of a bodge.
Can anybody explain what should return the throttle to low revs ? Is there a spring mechanism at the engine end or is it just the Morese lever pushing back the cable?
Any ideas ?
Any ideas ?
