Three Part Anode for Volvo Two Blade Prop
Ian_Rob
31 Jan 2008
I was under the impression that there is a recommended torque for the three part anodes (part no. 3858399) that are fitted to the Volvo Two Blade Prop but the accompanying instruction leaflet just says tighten them to ‘ensure good metallic contact’. Is there a specified value anywhere?
VicS
13 Jul 2002
If you use a regular size Alan Key I doubt you will over tighten. You will be amazed at how quickly they disappear!
+1
I believe the screws are M5 (requiring a 4mm Allen key) If this is so and they are A4 stainless steel then the standard torque is 6.9 Nm ( or 61 inch.lbs)
