blazeman999
New Member
I HAVE A PROBLEM WITH A LEAKING BANJO COUPLING ON FRONT OF FUEL PUMP. I REPLACED LIKE FOR LIKE WITH FIBRE WASHERS AND ONLY LASTED A COUPLE OF TEST RUNS BEFORE LEAK APPEARED AGAIN. WOULD COPPER WASHERS HELP? AND WHERE CAN I SOURCE THEM? ALSO HAD TO REMOVE OIL FILTER TO GET ACCESS TO BOLT AND IS THERE AN EASY WAY TO REFIT THE CATRIDGE CASING. (THE RUBBER WASHER KEPT BLOWING OUT AT TOP OF CASING).
