Achilles
The Thornycroft T90 is fitted with a manual oil pump which is used to pump out the old oil when it's time to change it. The pipe from this oil pump enters the sump through a nut and a very small amount of oil leaks out around this connection when the engine is running. It is a small amount but I'm concerned that it will get worse so would like to fix it. I've tightened the nut as much as I dare but this has made no difference. Does anyone have any detailed information on this connection and what parts I would need to fix it?
Thanks in advance.
Regards,
Kris
Thanks in advance.
Regards,
Kris
