willtaylor
I bought a Moody 333 with a Thornycroft 35 hp. It was going well enough. The surveyor pointed out that it was beginning to burn a little oil, but thought it quite serviceable. However, there were a number of relatively minor problems, mostly due to neglect by the unwell previous owner. Among them was the fact that the aft crankshaft oil seal was leaking. It seemed sensible to remove the engine for a thorough service, clean, and repaint. We could then easily clean out the engine compartment and modify exhaust etc.
I have received a bit of critical comment along the lines of ' It's only a Morris Marina engine ....... not really worth spending a lot on ......' that sort of stuff.
I thought it was a 1.5 litre BMC taxi engine orginally, and none the worse for that.
I have no problem with relatively unsophisticated machines so long as they work.
It seems to me that a 30-35 hp modern marine engine would cost a good deal more than a pretty big overhaul of a 20 year old BMC diesel.
The problem is, what would I have then? Is it likely to be reliable in itself for a number of years? I reckon most faults with marine engines come from ancillaries like water pumps, fuel and cooling systems. It's a sailing boat, but the big old lump under the centre cockpit is useful to get on and off moorings and would get us home ( I hope) or into harbour against wind and tide when needed.
I used it quite happily from the end of September until three weeks ago.
I shall welcome observations, opinions, advice - helpful thoughts and sympathy.
Regards,
Will Taylor
Regards,
Will Taylor
