rwterry
New Member
Thornycroft engine stalls when f\'wd or reverse gear engaged.
Everything worked fine on the 40 min. motor trip to the yard for a lift out. The cutlass bearing and stuffing in the stuffing box were replaced. Prior to re-launch everything was checked over and the propshaft turned easily by hand. When back in the water the engine was started, first time as normal, f'wd engaged and the engine stalled. It stalls in reverse as well.
A mechanic in the light of no other plausible explanation diagnosed a seized gearbox. The gearbox was replaced at no small cost but the engine still stalls. The engine can be turned over in gear on the starter motor with everything revolving OK but will not start. I did manage to get it to run for a short while by starting it in reverse but with the throttle fully open it only ran at tickover speed, there were not clouds of black smoke but just some unburnt fuel on the water surface.
I replaced the mechanical fuel lift pump about a month ago and it worked fine on the trip to the lift out. I have dissasembled the pump to check the diagphram etc. which is all OK. I have checked the fuel on/off tap and that is OK.
I have loosened the bleed screw on the injection pump whilst cranking the engine and got a squirt of diesel. The air filter is clean. I have replaced the fine fuel filter.
The engine is a Thornycroft 80D ( With mechanical stop lever.)
driving a ZF Hurth HWB100-2R gearbox and Darglow feathering prop.
I have run out of ideas now so any help is greatfully received.
Regards to all,
rwt
Regards to all,
rwt
