Steve_N
This can\'t work surely? - engine installation
My current project is the refit of a 20yr old Countess 37 fitted with a Volvo MD21B. Although the budget would allow for re-engineing, obviously I'd rather not if I don't have to and in fact the beast tests OK and runs well.
However, thanks to the relatively flat shaft angle and the down-angle reverse gear, the engine sits 'down by the head' by a few degrees i.e. the front end of the engine (on which sit water pump, thermostat housing, expansion tank etc.) is perhaps 2cm lower than the rear end. Although I never considered it before I think this is a problem: certainly when changing coolant ready for the winter, I couldn't get in as much as I drained out! I reckon that air remains trapped in the head due to the down angle..?
Now I can unbolt mountings and coupling and lift the front of the engine to fill it - but surely any air 'bubble' will just reform during normal running from air bubbles in the coolant..? However, it has survived 20 years to date like this.
Any thoughts?
Thanks, Steve
Any thoughts?
Thanks, Steve
