wipe_out
As the subject says I am thinking about fitting trim tabs to our new Merry Fisher 695..
Seems the two options are Bennett and Lenco.. From what I can see Lenco appear more popular on new boats which makes sense I guess being a simpler install.. Had Bennett tabs on the last boat and had no issue so I suppose there is little difference between the two and it's really just what you prefer..
At this stage I would lean toward the Lenco's for the simpler install and because access to the inside of the transom is very limited so might have to route the wires externally up the transom and then in through a gland somewhere..
Motivations are..
1) Being able to level the boat when people move around because is a small boat and does get affected by weight distribution quite easily..
2) Being able to more effectively keep the bow lower to slice through chop than using the outboard trim.
3) Hopefully have a lower plaining speed for crossing Poole Harbour (10kn limit). Currently have to do about 5kn or inefficiently push a bow wave..
What are your thoughts? Does is sound like a good idea for a small boat?
Next thought is to have automatic tab control although this is an expensive add-on and I am not sure it's worth it on a small boat.. The Mente control seems the best option but it costs more the the complete tab kit.. Do you think auto tab control is worth the price tag?
Thanks for any thoughts..
Motivations are..
