Things that need fixing on my boat
ricky_s
18 Jul 2005
Angmering
This is my current list of broken (or soon to be) bits for this season so far.
1. Anchor windlass.
2. Throttle cable.
3. Toilet wont flush.
4. Microwave buggered.
5. Manifolds starting to rust.
6. Tap dripping.
Quite a small list I suppose.
11 Jul 2005
Lancashire
I'm not sure where to start !
:D
Mal
jimmcgee
31 Jul 2006
1. Anchor windlass. number 1 son and rope
2. Throttle cable. number 2 wife and loud shouts to the back of the boat
3. Toilet wont flush. portapotie
4. Microwave buggered. wits that fur?
5. Manifolds starting to rust. been rusty since i got the boat
6. Tap dripping. 2 litre bottle from co op
Geoffs
15 Jun 2001
Wantage,Oxfordshire
Had a similar list, on similar boat to yours.
Anchor Windlass.
If a Maxwell, or probably even if not, I found that spade terminals on the dash switch were corroded, remade, and worked better. Also found a loose high current connector on contactor box in chain locker. Tightened that and windless worked even better. Had to strip foot switches and clean the contacts. Windlass now perfect.
Tap Dripping.
Half turn type, lifted cover off top of tap, unscrewed tap and pulled apart. Cleaned up plastic seals and reassembled. Tap still dripped. Pulled apart again and put thin layer of grease on plastic seals. Taps now perfect.
Toilet.
If electric, may be blocked. Needs stripping and service kit used. Lovely job!
I've had no problems with, manifolds, risers or throttle (touching wood), but then I have a Vilevo.
Geoffs
15 Jun 2001
Wantage,Oxfordshire
You are right of course, although some builders choose better quality bits and pieces.
I doubt Larson actually make taps!
Oh and good old BeeJay only trying to wind me up, it worked!
cem
20 Apr 2011
bicester...too dam far from the water
www.solutions4feet.com
Well according the the survey.....
The following need attention
The FM radio
The fresh water system (may be just there was no water in the tank)
the bilge pump (no water in the bilge?????)
and the anchor chain and warp
So based on that, IF I decide to buy this boat with so much wrong with it what deal should I try and cut ;)
Oh yes and there was a worn anode on the cavitation plate of the drive
ricky_s
18 Jul 2005
Angmering
The FM radio
I wouldn't bother with that boat! :D
