robbieg
Next weekend if the weather gods are kind I intend to deal with one or two dings on my topside.
My boat is offwhite in colour & I've previously spent time mixing gelcote resin & pigments (all bluecote products) to get a reasonable match when I had to repair a small flat area on the deck. When sanded & polished this blends in fine.
The only problem is that the gelcote resin, hardener & pigment mix is quite runny-not a problem on a flat surface but I imagine it will be when trying to fill holes on a vertical surface.
Can I therefore thicken the gelcote mix to a putty like consistence & if so with what. If not how do you approach these repairs-wait until the mix starts to kick & then work like crazy. Any tips appreciated-I've done a search & found lots on gelcote repairs but not anything that addresses this. Thanks.
