Thermostatic Shower Mixer Bar: suddenly can't get hot enough?
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
I bought a relatively cheap Thermostatic Shower Mixer Bar that looks a bit like this one:
It has worked fine for a couple of years of intermittent use, but on this trip I discovered that it can no longer get hot enough, even with the control turned past the safety stop, which was where I normally left it. The temperature varies OK, but is limited to luke warm.
If it makes a difference, mine is rotated 90 degrees ACW.
Any tips for fixing it?
Can I suggest moving the temperature control knob from full hot to full cold a few times whilst the shower is running. The thermostatic cartridge can sometimes become stuck in one position by scale build-up (particularly if the setting is left in one position). Ideally this should be done once a month to keep all free & running sweet
