Oscarpop
I'm not up to this, so for my own curiosity can someone do some physics problem for me.
Bronze cylinder ( the nut on my prop).
If it is an average composition bronze and I heat it from zero degrees to say 150 degrees .
If its internal diameter at zero degrees is 30mm, what will it be at 150 degrees.
( fully aware that the s/s shaft will also heat up and expand at a lower rate )
Many thanks
Many thanks
