Refueler
My 1970's boat ... Sunrider 25 ... has over last number of years had its teak rubbing strake repaired / refixed / filled ... but it was obvious that these actions were only delaying the inevitable.
The list of work needed :
Foam backed vinyl Headlining replace - I have Van lining with spray adhesive already for the job. Forecabin already done. Main cabin still to do.
Teak rubbing strake rotted and now fastenings no longer holding it in place.
Wood trim covering cabin 'furniture' to GRP joints to replace
New sprayhood - mainsail cover - dodgers.
As with old boats - the list can be as long as you still have paper to write on - or you can accept its an old boat and select accordingly.
The main area of concern is that Rubbing Strake. I approached a local yard. Discussed whether to replace the teak with 'wood' or to accept a rubber based alternative. They wanted to replace with steamed Oak - which seems a bit OTT in my mind ... but of course Teak is not so easily obtained or as good quality as the 1970's.
I am considering doing the job myself - but realistic in realising my work would likely not be as good as the yards. To steam 8m lengths of wood as well is not a task to take on lightly.
Interested to read of anybody who has taken on such a job (older GRP boats particularly) ...
Here is the strake when it was still in good condition ! But shows clearly its relation to level of deck ... it does cover the Hull to Deck joint....
One of the repairs ... before shaping and staining to blend in ... can be seen that surrounding teak is 'soft' and soon to fail - which in fact it has now ...
It would appear that the teak strake was held by screws into the GRP as there are no nuts or retention parts on inside of hull. This fact is also one of the reasons I am considering rubber replacement instead. Rubber fendering would be easier to fix without steaming by same method.
Always interested to hear of others solutions ...
