Slowboat35
I have a new engine installation that is proving to be a great deal noisier than the original. A 3GM was changed for a Beta 35 and a Featherstream prop added on the old shaft (1 ¼" by 1 metre). The old vibration coupling was retained (see seperate post).
Although the new engine runs as smooth as you'd expect in neutral once in gear it sounds as if it is stirring a barrel full of loose nuts and bolts - horrendous din.
There is no obvious vibration (in 10 ton boat not surprisinng I suspect) but the noise sounds awful. So bad anyting over ⅔ revs is too much for me to stand.
Setup is engine on 4 flexible mounts via vibration coupling through grease-packed shaft gland and cutless bearing to prop maybe 2" further out.
How can I as a capable but non-specialised mechanic check alignments are OK?
Can this be done in the water?
