burgundyben
I should have known better and Latestarter will tell me off.
The dash said stbd engine was running at 100degs, so I sorted a good clean descaled spare headertank/heat exchanger, fitted it with a new thermostat, new impeller with new cover plate, seemed to be masses of raw water flooding through.
Ran the engine up to temp, dash still says 100 degs.
Borrowed an infra red thermometer, engine is spot on at 80 degs, dash is wrong....sod it. not sure if gauge or sender yet, will do some swapping over to find out. Should have done that in the first place!
Berk.
Berk.
