domlee
How about this for a pub argument? I was reading about a procedure for 'hot metal spraying' a crankshaft to build up wear marks, then the crankshaft was reground to the original profile etc. What about 'hot metal spraying' a hull with liquid copper to a thickness of 1 or 2 mm? All you would need would be the heat source, a big compressor and the copper (copper is very cheap at the moment). The initial layer would fuse with the GRP of the hull (possibly with a thermo-reacting epoxy/plastic layer to aid ahhesion of initial copper layer) The copper coat would last for at least 30 years, no problem- no recoating and no lift outs! I think the idea has merits, any thoughts?
