zoidberg
Replacing a pair of halyard sheaves, I'm presented with two profiles - rounded and V-shaped. What's to choose between them - and does it really matter?
I think the limited contact area from braid in the V shape would cause a lot more wear on the halyard - the U profile distributes the load/wear more evenly.Interesting question and the answers given are undoubtedly correct but would a v shape not only work for braid but also give additional ‘safety’ in that the halyard would take the v shape and be less likely to slip out of the rounded sleeve?
I do tend to overthink things and be a little odd.
Yes, I imagine you are right.I think the limited contact area from braid in the V shape would cause a lot more wear on the halyard - the U profile distributes the load/wear more evenly.
Conversely wire in a U sheeve will tend to cause a lot of wear to the sheeve - cutting a groove in it
Tracked down the originals, from Selden,I think the limited contact area from braid in the V shape would cause a lot more wear on the halyard - the U profile distributes the load/wear more evenly.
